how to clean points
2.6K views 1 reply 2 participants last post by  Rich Ard
#1 ·
I don't know if my hard starting 450 probs. is related to dirty points.
anyways, how do I clean points?
Before winter storage, for knowledge sake I wanted to take the points cover off and get a good look at these primitive things.
but it was so TIGHT that I couldn't even get the screws to turn to get the damn thing off.
#2 ·
Ha - just bookmarked this myself. From Dan's MC:
Points tend to blacken with corrosion when left sitting for a long period of time. You can clean them with a points file. I don't use the metal ones that look like small files. I never could get them to work right, the metal used in points is just too hard to file good. It's also not a real good idea to file points if they are badly pitted because it cuts down on their contact area. If you do file badly pitted points you must file ALL the pits away. I use a flexible type that has grinding compound imbedded in it, or a piece of 100 grit sand paper folded back to back. This just cleans up the point surface. If the points are badly pitted, replace them. Now blow everything clean with compressed air and clean with some contact cleaner. Finally, clean the points with a 1/4 inch strip of paper cut from a 3 by 5 inch card and dipped in acetone. Also, put a bit of points grease on the points cam, points heel and the points lubricating felt. If the felt is old and dry, lube it with grease and put one drop of oil on it. If the felt is old and dry, and you only put grease on it, the dry center will pull the grease into the center and away from where you want it... on the points heel. The oil kinda "charges" the dry felt center, preventing
