Hi,
Instead of shimming your cam with these very thin shims (which are vulnerable and sometimes end up as grinded up sheet metal), I use the thickness of the gaskets self to "shim" the cams. I have different sizes (thickness) of sheet gasket material, this way I can manipulate the clearance.
When you have a few of the standard pré-cut Honda or aftermarket gaskets you can also measure the thikness, they differ, a little puzzling and voilà, no shims needed, saves a few bucks too.
Jensen
btw, In general, give the gaskets time to get set to the torque of the bolts, no matter what method you use. Measure directly after tightening the bolts, and after one or two days again. If the gap is exactly according spec directly after tightening the next day the gap can be too small ! (I have seen that a few times, especially with cheap aftermarket pré-cut gaskets).
