Anti-Seize Compounds
4K views 9 replies 6 participants last post by  Boomer343
#1 ·
Which screws and bolts should anti-seize compounds be used on?
There are many different types of anti-seize compounds (aluminum, copper, nickel, silver, molybdenum disulfide, and graphite) or grease for different applications: metal types, heat exposure etc. Is there a universal one which works for all the applications on these old bike or do I need several types?
Thank you for answering
#2 ·
Anti-seize should be used on any bolt that is steel that is going to be threaded into aluminum. I also use it on any bolt or nut that is somewhat exposed to the weather that I forsee needing to be taken apart at a later date like say the axle nuts, swing arm nuts, cap nuts on the bottoms of the forks, etc.
I've had the same bottle of permatex anti-sieze for years. It has a high heat range and its usable on most metals.
#3 ·
I also like the permatex product. A container lasts forever. I have a large one with a brush in the lid, and I think that it will outlive me. I use anti-seize on spark plug threads and any steel (including stainless) fastener going into aluminum.
#4 ·
Should always use anti-seize compound on stainless steel fasteners. Otherwise galling will lock it forever.
#7 ·
For very dissimilar metals, go with the nickel based system. Also the best for stainless steel. The nickel is not as active as copper or aluminum.
#8 ·
Permatex
Thanks tepetit53, Permatex Q&A Resource agrees with you. They should put you on their payroll as a consultant! :cool:
From: Permatex Information [mailto:Info@Permatex.com]
Sent: Wednesday, May 10, 2017 4:18 PM
Subject: RE: New submission from Permatex.com - contact Us - Product App - Nickel Anti-Seize
Thank you for contacting us. For all these applications we recommend out Nickel Anti-Seize (77124). This is our highest temperature anti-seize making it great for exhaust applications and being as it is nickel-based it is non-reactive so works well with dissimilar metals.
Regards,
Technical Services
ITW - Permatex
Sent: Wednesday, May 10, 2017 3:36 PM
To: Product Application <ProductApplication@Permatex.com>
Subject: New submission from Permatex.com - contact Us - Product App
Message: I am restoring a 1970 Honda CL-350 motorcycle and need an anti-seize compound for use on spark plugs, exhaust manifold bolts, and dissimilar metal fasteners (stainless steel, brass, copper, steel into aluminum). Is there one product can do it all well?
#9 ·
Hmm. Might interfere with my retirement plans. Trying to get the workshop all straightened out for that day.
#10 ·
The longer I pulled wrenches the less I liked anti seize. It's like that hot sauce commercial where the old lady says ...I put that **** on everything!
I have flushed out spark plug wells filled with it and have seen misfires due to some products being dielectric. BTW NGK does not recommend anti seize on it's spark plugs as they have a coating already on their threads.
A very small amount goes a very long way. If you have to use it for stainless to aluminum then I would suggest a stick style product and not the huge butt brush from the can.
https://www.amazon.com/Loctite-37617-Silver-Grade-Anti-Seize-20-gram/dp/B0053ZS1Z8
Another trick to prevent both loosening from vibration and galling is to use a thin smear of silicone rtv on fasteners.
