New rider here. No major clutch issues, but 3 that are annoying:
1) Bike will start in gear, whether i pull the clutch in or not. That's probably not how it was designed.
What I did: replaced OEM SWITCH, FR. LEVER (35330-413-003) in the switch assembly housing on the handlebar, as I assumed that switch was faulty & not doing it's job. That didn't work. Suggestions?
2) When pressing the start button to start the bike, there is always a 2-3 second pause before it actually starts cranking. Almost like a delay that shouldn't be there. Suggestions?
3) When bike is in motion I can easily move the gear back to Neutral. Problem is when bike is parked (in gear) or if the bike is at a stop already (in gear), I cannot move the gear to neutral. Any ideas on an adjustment that needs to be made?
Thanks - Dave
Thanks - Dave
