I replaced the regulator/rectifier in my 72 CB450 with the one from Common-Motor. It had instructions, which I followed. Unfortunately, I've got zombie draw on the battery now. I had battery drain a bunch, and thought it was the charging system, but I tested the rectifier and it's charging just fine. The battery is up in normal operating levels after the bike is running, so it's getting charged. It's when it was sitting that it started to have issues. I finally verified this by disconnecting the ground connection, and putting a volt meter between the ground on the battery and the ground wire, and seeing voltage, and disconnecting wires until I didn't have any draw anymore.
Long story short, I can now read draw between the CASE of the regulator/rectifier and the ground. I think that means this regulator/rectifier is bad. There seems to be a short between the 12V connection and the case (ground). Can anyone confirm this for me? There shouldn't be any connection between the 12V pole (or any of the poles) and the casing of the regulator (ground), right?
