petcock removal and installation
6.6K views 1 reply 2 participants last post by  outobie
sounds like the little wizzer seal is worn out...you can replace without removing from the tank
although it's a good idea to remove clean out and replace all the seals.
to remove from the tank, unscrew the bottom bowl with a 10mm wrench
then remove the phillips head screw connecting the petcock to the tank
