I'm running the Ignitech unit on the road bike, since 2013. No TPS unit.
SPARKER DC-CDI-P2 - IgniTech P?elou? There are several threads concerning this, use these search terms on Google to find them all
"ignitech hondatwins.net site:www.hondatwins.net"
Benefits are smooth power, lower idle speed if desired, good fuel mileage, rev limiter. I can get an even idle at @850 rpm. On a US tour in 2014 the best mileage was 71.79 mpg once. Running 70 mph plus I hit the mid 50's, under 60 I'm in the mid 60's. My rev limiter is set for 10,000.
Full disclosure on the road bike, it's modified. Ceramic coated pistons, tuned 2-1 exhaust, VB22 carbs, GM coil conversion, GL1000 stator. Lots of other mod's but unrelated to the engine performance.
I was the first one to do this so there was an issue with the pickup programming from Ignitech, easily solved and no one else has had that happen. The unit is supposed to be able to be programmed while the engine is running but I've never been able to do that, have to turn it off to reprogram. Could be the old computers I was using, haven't tried with this new one yet.
Here's the final programming I did, note that I started retarding the timing at 8K. I was about to wander the US and felt this would help in the event of getting crappy fuel causing detonation.
This what my power curves look like
