86 nighthawk 450 A.C.E. cruiser wannabe project? or Indian inspired Hon-dian?
14K views 69 replies 11 participants last post by  Paul F
Looks cool but you might want to consider a different tank as well. It seems a bit out of place especially with the fenders.
Maybe a tank from a Shadow or a Rebel?
how about this fix for the caps, i ran a depth gauge down and found a 1 1/4" long x 3/16" diameter piece of copper can replace the spring and resistor being squeezed slightly by the threaded end contacting the plug. will replacing these internal parts with a solid section of copper eliminate the restriction?
Yes this will work. That is essentially the only difference between a resistored and non-resistored cap. Although why not use the existing spring? Just replace the resistor with a piece of copper wire of the same length.
You're already spending a bit on the fenders for the look, might as well get a better tank that will match better IMO.
Check out the Honda Shadow or Rebel tanks like I suggested earlier. One or both of those might even be a straight drop in fit too.
well technical you're both right.
Sharper angled shocks will make them too soft AND resulting in a rougher ride since you'll be bouncing all over the place LOL
