I just cracked my top triple clamp on my CB450 K5 as I didn't know there needed to be a spacer on the pinch bolt. I do now of course. So am looking to replace same if anyone has one at a reasonable price and is willing to post to Perth Australia (at my cost of course)
IF this is for a "cafe' " bike, and you can live without the rubber cushioned handlebar risers, the bridge (top triple) from ANY of the pre-1977 Honda SOHC 750's will fit and has the same tube size, spacing, and offset.....Meter mounts MAY have to be adapted, but otherwise, a perfect fit.....
IF you are restoring to original, of course only a "pinch-type" 450 bridge will work.....
Thanks for the info. Yes my 450 is a custom bike and I did consider the clamp from a 750 but much prefer the look of the original clamp with the removable cushioned clamps. Will see how I go sourcing an original. If not may be forced to go with the 750 clamp
I have a spare top clamp with risers etc. will need a good cleanup but is in good shape
Hi Mr McGoo,
If Joules doesn't want the triple tree, would you be prepared to ship to Australia?
cheers
Gazza
PM sent.
Gazza
