1 - 12 of 12 Posts
WTB - 1981 CM400C Side Covers (Left & Right)
Looking for a set, but I'll start with the left or right.
Repaint or unpainted are fine, but please no real damage or missing tabs.
I think the last unmolested pair is in storage somewhere in the middle ease, right beside the Holy Grail.
Seriously, they do exist, but you'll likely need patience.
I've got a set I could be persuaded to part with.
I'll post some pictures asap tomorrow.
Wow, stock paint too, those are pretty sweet.
Here's the pics of mine mentioned above, flat black but no damage.
20180217_140454_resized.jpg 20180217_140447_resized.jpg 20180217_140428_resized.jpg 20180217_140343_resized.jpg 20180217_140339_resized.jpg 20180217_140332_resized.jpg 20180217_140327_resized.jpg 20180217_140317_resized.jpg
I still have the cover set, it took me over a year to find them and that was almost a decade ago.
I'm probably asking too much for them and should just pack them away for another decade instead of putting them back on the bike.
Words of advice on the side covers.
The rear tab is the one that always breaks off. Lube the rubber with some silicon grease. Preventive repair for the tab is to drill several small holes at the base and on the tab. Liberally coat the tab with JB Weld, steel type, so it squeezes thru those holes. Fill the inside of the tab if you can and spread it on to the cover itself.
battery side tabs. I broke my first and only tab soon after I bought my first CM new in 1979. First time winterizing I off course took the battery out. UGH!. I used to white lithium grease them. I have a couple of extra sets and 1, I have experimented. I took a rasp or file and gently drew it across the tab (lightly). 1 stroke at a time. After each stroke I replaced it so as not to over do it and have it fling off or even flutter when it catches the wind. Three light strokes and "Voila" easy on easy off. I still use a film of lithium grease but there is no twisting and anxiety. They are a commodity and should be treated as such.
Over on SOHC/4 the big tip is to replace those old and dried out rubber grommets, getting the side covers off when you want is important, but keeping them on the bike when you want them to stay on is another. Someone had a story of one of the early CB750 side covers flying off on the highway and being run over by oncoming traffic :eek:
1 - 12 of 12 Posts
