1 - 10 of 10 Posts
Stick some baffles into the pipes..... The 450 "likes" some restriction..... Bill will probably suggest something too.... What size jets are you running?
OK...But several sizes were "stock"... Yours could be 130's or 150's
I believe you are so "rich" in the jetting you are "over-supplying" fuel at wide open...That's why I asked for the particular size in your carbs...
if your avatar is a pic of your bike those short headers won't turn any rpms anyway, yes it needs back pressure but it needs room in the pipes to scavange the exhaust gasses also
the pipes now run under the bike to about an inch from the rear tire i think the jets were 148's i could be wrong i'll pull the carbs and get back with the mains and secondaries
Not so worried about the pilot and secondaries...it seems to run well through their range....I think the mains are too rich when the slide (piston) comes fully open and the needle is at its thinnest, and that is happening too soon as the free flowing exhaust and pods allow it breathe better. opening the carb up more /sooner than necessary...perhaps too well...Can't really see the pods....are they sufficiently oiled-up?
Another thing that can cause similar top end symptoms is imbalanced carb settings/synchronization....
1 - 10 of 10 Posts
