So i just got this honda cb500 t tank dirt cheap but in good condition and then i realized that the gas cap is not the right one or its poorly welded.should i just remove the whole thing and get one of those twist on caps? Suggestions? image.jpg image.jpg
that is aligneed correctly. the Latch (it's missing) is offset to the right. The hook that catches the cap pin is in the center, but the release button is to the right of the cap. That is why the bracket on the tank is offset. Your cap hinge looks a little beat, maybe twisted...
Does this pic help:
Does this pic help:
Perfect! Thank you, the other tank i have just latches straight down so i was a bit confused. Now to find the parts! Thanks again.
Im also assuming the last person who had the tank was unaware if this and tried bending the cap to correct it. So ill have to straighten it
