I've been doing some work on my bike this fall but it looks like winter hit before I could get it back out again. I read an article on winterizing your bike (http://www.z1enterprises.com/bikemaintenance.aspx) which has some great advice but I also ended up with a few questions.
While I was working on the bike the past two months, the gas tank was mostly (but not totally) filled. The upper inside began to rust just slightly. If I run my finger around the inside I can wipe a bit of it off. So what's the best way to avoid rust and keep the carbs clean over the winter? Here's what I've been thinking:
1) Completely fill the gas tank (treated with STA-BIL). Run for 5 minutes to get it in the carbs.
2) Completely drain the tank/carbs.
Which method would be best though? If I fill it, does it need to be filled to the brim? If I drain it, does it need to be bone dry? Is the very slight bit of rust in the tank right now going to cause me a headache later and if so, is there an easy way to clean it out?
Any other advice on winter bike care would be great.
