It can be fitted to the bike and wired in.....Your "no modifications" is somewhat hopeful, as the mount holes probably won't line up and will need to be drilled in your fender...... So as asked, the answer to the question is likely "NO"........
do you know of any that fit like I want?
The stock one..... Any change or modification generally requires some adapting.....
If you want bolt on parts, you'll probably have to look at that other H brand from Milwaukee ;)
Otherwise, where there's a will there's a way. People in Cuba keep 1957 Chevies running to this day. Anything is possible. Part of the fun is figuring out how and blazing that trail with enough stubbornness to make it happen.
