CB250 N Superdream carburettor on CB450 DX ('89)?
Hi all,
A quick introduction...
Over the past few months I've been getting acquainted with and rebuilding / modding an old CB450DX (UK) picked up for a few hundred quid, that I hope to make Cafe/Brat style.
It already had the tail chopped, half the paint stripped and generally covered in grime and needed a lot of TLC, especially the electrics, but the engine appeared to be pretty good condition.
In the process of cleaning the carbs up and trying to loosen the butterflies that had seized, the aluminium throttle pulley lost it's teeth/fingers that hold the cable end.
I can't find any old DX carbs for parts (not wanting to spend hundreds) and wonder if a CB 250 carb is similar enough in dimensions to use for parts - primarily to replace the throttle pulley??
Any thoughts greatly appreciated.
I'll post a few pictures below....
The broken carb pulley
Auto part Carburetor Automotive engine part Vehicle Engine
Before work started:
Land vehicle Vehicle Motorcycle Motor vehicle Automotive tire
Land vehicle Vehicle Motorcycle Motor vehicle Fuel tank
And current condition:
Progress can also be followed on my Instagram https://www.instagram.com/webbwonders/
Welcome to the forum. IMHO, the carbs from the 250 would be too small for the 450, but that cable guide may fit both.
Thanks dtsmjr8dan, I suspected that would be the case using a 250 on a 450, although they do look very similar in construction so wondered if honda used the same carb across different models.
:grin:
