Im getting pistons honed, new rings, whole top end rebuildWhy not just get the matching over size pistons and get the cylinders rebored ?
Simply replacing the rings may not cure your low compression / oil burning problem.
Are those standard size? And did you have to gap them?I ordered them at cmsnl.com
https://www.cmsnl.com/products/13011354305-ring-setpiston_13011354003
Complete set for two pistons for €28!
No bore wear then ?Im getting pistons honed, new rings, whole top end rebuild
Doesn’t appear to be wear. I dropped it off at the shop for honing, so they’ll be able to make sure there isnt any.No bore wear then ?
Yes, those are standard size... Mine did not have to be gapped because they were perfectly within spec when I measured them in the cylinder. They were actually on the tight end of the spec range. I only deglazed the cylinder.Are those standard size? And did you have to gap them?
Davidsilvers only sells oversize and cmsnl doesn’t ship to Us when I tried.I would never buy generic aftermarket rings unless they are from a reputable manufacturer. In the time this topic has been running, you could have had them delivered by David Silver or cmsnl.
