1 - 20 of 28 Posts
Bought a carb sync gauge off amazon because it said it "worked with most Hondas". Turns out a 1975 CB 360 is not most hondas.
The brass adaptor that is supposed to be screwed into each car does not fit. It is 5mm.
I've seen 6mm versions sold but they're all 1mm pitch. I believe that the carbs have a .75mm pitch.
Does anyone know where to find a suitable workaround? My last ditch though was cut the end off the ones I've got and buy a tap and die set but that's more money than I was hoping to spend.
The product in question:
Amazon.com: Vacuum Carburetor Synchronizer Carb Sync Gauge 2 Cylinder Bike Cb Cl 350: Automotive
Have you tried the M6-1 in the port yet? I have never needed a M6-.75 but if I did, I would probably contact Z1Enterprises.
TOOLS
I haven't tried 6x1 yet. All I have is the 5x1 and that's too small.
Do you think I might be able to just make a 6x1 work? There's a small brass screw in the carbs now and I put it on a thread gauge and it's definitely 6x.75. I just wanted to make sure before I pay another $14 to have the 6x1 mailed to me.
Got the nipples today (I'll be using that term instead of adapters) and they seem to screw in very nicely. Wish the outer shank was a touch longer, but it should work. I meant to get the brass ones, but got stainless instead. Will be careful screwing them in. I ended up fitting a small o-ring on them, hopefully to help out with the seal.
Next step is to buy some small diameter tubing. Although they taper, I assume ill need a small hose clamp as well.
Lastly, the inner diameter is *very* small (in my understanding, just enough to let a spark through, but not enough to let much subsequent blackpowder explosion back out. Think I will probably drill them out a bit.
Will report back with how they actually work...
Did you see what hondacb360.com has?
Discussion Starter #8
A guy at a local repair shop told me they usually just buy brass screws and drill holes right through them. Might just try that for simplicity.
A small hole is good, dampens vibrations/pulsations. I would use a sealant rather than the o-ring. Less chance of vibration letting them fall out then put a plug on it.
you're talking about leaving them in the carbs all the time?
also, somebody finally enlightened me to your phonetic username... *headsmack*
I would leave them in with a rubber plug blocking them. Glad you got the user name. I was trying to use a name hard to spam, and maybe a little 'l33t' appearing. I think I am too old to be l33t though. Lol
Look just like the ones I was talking about. I just used tiny zip ties as clamps. Cheap n easy. I was also going to use o rings like you but I forgot to pick some up so I clipped a tiny length of the vacuum tubing and used it. Overall the setup worked great.
Sent from my SM-G900V using Tapatalk
I make them as a service for 360 owners
Early Kawasaki KZ400 uses almost exactly the same carb but uses 6x1 thread
wanted to check back in and say that the blackpowder nipples do work - synched carbs this weekend and the bike is much happier off the line. i may be imagining it, but i feel like the tach needle also bounces around less...
depending on the ID of the vacuum tubing, you may need to use a zip tie where it mates to the nipples.
that all said, i assume the adaptors that crazypj makes are more tailor fit to the job...
I make them more like this
Somewhat depends what blanks I get hold of
A bit late with this, but...
Motion Pro has nipples, both 6x1.0 and 5x0.8
Motion Pro
Install "permanently", the rubber caps are available at any auto part store for cheep when the time comes.
Motion Pro
I guess you didn't actually read the title?
Motion Pro doesn't make adapters to fit, unless you buy the rather expensive professional kit.
I don't like leaving the plugs permanently installed, I've seen way too many Kawasaki's and Suzuki's with problems because a cap split or 'went missing'
A little timing misadventure or a quick throttle close, a backfire, and those caps take off like rubber bullets....LOL...
'You'll shoot your eye out' LOL :D
1 - 20 of 28 Posts
