1 - 10 of 10 Posts
I need a secondary Main jet bigger than 110. Just wondering where I can get a few different sizes.
This has been the un-answered question for wayyy too long. Surely someone has experience/knowledge on this subject. I remember twinfan (?) had a lead on 360 carb jets supplier once...but my memory aint so great... :roll:
Try Sudco is my guess, if you have a digital caliper you could measure the jets dimensions and compare to their product list.
I don't know if the flow scale is the same, but large round Mikuni jets & Keihin jets are threaded the same.
I learned this by trying the extra jets I had for my stock Keihin carbs in my Mikunis as a starting point on my 360.
They screw right in with no effort. I assume the Mikuni jets should do the same into the Keihins.
( I had drilled some Keihin jets and just wanted something close to start with)
I may have a source for all carb parts.
www.motorcyclecarbs.com I ordred a choke assembly for my 93 RM250 last nite. HOpefully he'll come through on the jets and such.
I'll keep you all posted.
Kei-Hin and Mikuni don't use same thread?
One is 0.75mm pitch and the other 0.8mm pitch.
If they screwed right in, I can only assume someone has 'modified' them previously.
I've been making my own jets if I can't find them out of a different carb ( have a lot of old jets, run out of 110+ though :( )
PJ
Do you have any 115 or 120?
PJ
Actually, from what I can tell from my recent digging for Mikuni information, There are 3 different types of Mikuni main jets. Two of those (small & large round I believe) are threaded the same and the hex jet is different. It was a large round Mikuni jets I replaced with Keihins.
No, those Keihin jets were not modified, I know that as a fact. I may have to go out to the garage & actually try some large & small round Mikuni jets in my junk Keihins just to find out for sure. Make sure they swap both ways.
Honda jets go by hole size so you can drill out to 115 (1.15mm) or 120 (1.20mm)
112 drill is available but a bit pricey, solid carbide breaks very easy in small sizes unless you have a rigid machine spinning at high rpm
I used a pitch gauge and magnifier to check jets.
PJ
1 - 10 of 10 Posts
