1975 CB 360t I've fully restored and upgraded by hand. Almost to the end and I can't remember where this goes. Hand sanded every part and rattled can after that. All new bearing/brakes/tires/electrical/hoses/cables...you get the point. Tank and side panels are about to get here from the paint dude and I have no idea where this goes. I'll post a pic as well as a pic I took of the bike earlier. It was a mess when I got it.
Let me know as soon as possible
Thanks
Discussion Starter · #2 ·
Hello? Am I doing this wrong or should I ask in another part of the forum? I've asked in other forums and still have received no answer. Help if you can and if this is a dumb question, I'll figure it out eventually.
I have no clue. Big hole is 10mm looks like. 2 are 8mm looks like. Face side on the 10mm hole is showing round for the nut to roll over the paint? Where you flip it, it shows a frame or engine brace face, meaning, no circular moves on that side.
Then it's look for a 10mm bolt, line it up faced or flipped. It only assembles one way.
Thanks all. Found it. Goes to the Horn but I didn't notice it because my new horn had a chrome bracket to hold it and I used that one. I'm going to put the factory one back on because of the rubber inserts that should have a vibration reduction (a bit).
Thanks everyone.
