So... I broke the bike out today from winter storage. I basically kept it outside and covered and kept the tank and carbs full of stabil. I didn't drain them hoping the stabil would keep the fuel from gumming up. I was correct because the bike started on the second kick. So I rode it up and down the block, and then about 12 miles into town. Took a break there, and began riding it back. About 10 miles into the return trip my dummy/oil light came on. I limped it over the crest of a hill for another 15 seconds and then cut the engine and coasted down the hill to a safe spot in a parking lot.
Thinking I stupidly forgot to store it topped off on oil, I put two quarts in it, which probably overfilled it a bit. I know, I'm dumb for not checking before jumping off on a ride but I remember topping it off before putting it away, but I guess it could be a little low as it has a leak and I did take it out a few times during a nice week.
I start it again and the dummy light stays on despite having more than enough oil in it. At this point I'm weighing risk vs reward of letting it continue to run and trying to limp it home, and I know I will not be rebuilding this engine even if I had the time and money at this point so.. considering I had no noises or other symptoms I guessed it was a faulty sensor decided to risk it.
The bike runs fine at idle, but as soon as I start to go power drops, RPMS drop despite throttle position and it dies. Then you can kick it right back over and it will run happily while not in gear. As soon as you let off the clutch its start losing power and stalls again. The dummy light is on the entire time. The standard oil leak that I've decided to live with has also appearently gotten much worse because it began smoking like crazy from oil dripping on the power chamber. It usually does, but not to the amount it was after all this started. I couldnt find a definite source but the head and base gaskets looked intact and all I could see was more oil on the underside so thats anyones guess.
To me it seems like I lost compression (idles but won't move), or maybe it has something to do with case pressure? (Oil leak bad enough the dummy light stays on and maybe some compression loss that way?) Faulty light and worsening electrical problem (less likely), or... who knows? It does have a bad headbolt with a helicoil so now I'm wondering if that let go too and the surrounding bolts arent enough to keep a good seal around the head....?
But unless its something simple I think I may be done with this. The case damage to the head bolt threads doesnt make it worth rebuilding to me and I said I'd swap a motor in next time. Unfortantely I'm in PA school and in my clincal years which means full time work as a medical provider and studying so no time or money to deal with this. I know if I sell it I won't get much at all but.. not sure what to do some here. Only has a season on the rebuild I did..
