Hey guys, I have some yellow creame colored stuff all over my gas tank that I am not sure if its sealant or old gas residue. My cb that I bought was only sitting for a year-ish. Heres some pics it's been soaking in vinegar for the past couple days and so far, no results. The stuff is still stuck on. Also I washed my bike and now the electrical system isnt working when I turn the key. Did i short something out? What should I look for/ do? Thanks -Eli
312383
If that were my bike/tank - id take the tank off completely and pressure wash the inside to get most of that out of there. Looks like someone applied way too much tank sealant.
also It’s very likely when you washed the bike water got in somewhere and shorted something. Check your fuses and replace if necessary.
That looks like Kreem tank liner. Some have had luck removing it with acetone, others have heated the tank up with a torch to burn it out. It would be best to get it out of there so you can assess the true condition of the tank. It will eventually fail, especially when it is applied incorrectly.
Discussion Starter #4
Alrighty ya, I wanna get it out, I think it's why my carbs got clogged. I'm gonna soak the tank in acetone, thanks for the help guys!
Acetone will eat the paint off your tank too...
Also acetone will work better warm. Perhaps you have a sunny spot you can set the tank? A little agitation is good too.
You could always have it Media Blasted. If they know what they are doing, Media Blasting is Amazing!
Oh, and Yes, I would say it was a poor attempt at sealing the tank.
