1 - 20 of 76 Posts
After decades of riding bicycles I got the throttle fever last winter. Started with a KTM two-stroke that I’ve been having fun riding off-road. A friend of mine put a bug in my ear with his old CB restoration projects. And before I knew it, I ended up with this 1975 CL360. Engine seems to be in good shape. Tank and seat are in great shape. Missing some parts, but my buddy assured me it’s doable to get it running again. So we shall see!
Discussion Starter #2
First trip to the salvage yard. Kickstarter. Cool scrambler bars off an SL from the early ‘70s. A shift lever that needed to get bent right. Easy enough.
Discussion Starter #5
Left controls and new clutch lever blade installed! Had to make the wiring hole a little bigger since I was fitting four cables through while the old SL setup only had two. This bit did the charm we did a bit of string and rubbing alcohol for lube. Had to break off the set pin on the control as well because the bars didn’t have a hole for it. Routing the wiring under the control was a bit of a mystery at first but I figured out how it was supposed to naturally fit.
SL exhaust too? Cool bike. Check the top end...
Actually, I hate to tell you, but SL350 pipes simply turn upward slightly and they aren't chrome plated. The way those exhaust pipes are designed, looks like they simply allow for the mufflers, to be at a slightly higher level & do straight out the back. I've never looked very closely at a 360, but they may be just stock CB360 pipes, without mufflers mounted, I'm not sure, I just know they aren't SL pipes. Sorry,
Discussion Starter #10
Oh yes you’re totally right those aren’t off an SL. Probably off a CB but I’d prefer to find a way to do high pipes.
Discussion Starter #11
Electrical adventures this weekend. Bike didn’t come with a regulator, so I just got the combo reg/rec to upgrade the charging. Easy enough to set it up once I figured out the wiring diagram. I did waste a fair bit of time puzzling over the harness, trying to figure out the wiring mod recommended by Common Motor to connect the two wires coming off the stator. I’ll save that one for later I guess.
New flasher relay was a quick fix as well.
Up front, I replaced the rubber bumpers for the bar clamp, although I was disappointed that they still felt a bit wiggly. Oh well, they were inexpensive.
...although I was disappointed that they still felt a bit wiggly.
There is normally a bit of movement in the rubber insulators. They're there to help reduce vibration so if they were harder/stiffer, they wouldn't do as good a job. And as far as any parts you need like the rec/reg combo, there are many sources for good quality parts - just ask an opinion here before buying the first listing you see, often there's a significant difference in price. Take a look at this to get an idea of what else is out there.
Discussion Starter #13
The reg/rec I got from Common seemed fine. Have you heard any negative reviews of that one or was that more of a general FYI?
Common is a good place to shop for ideas, then google around for deals. Heck even Dime City is cheaper some times. One of my favorite places is 4into1.com They sell all kinds of goodies for all types of bikes not just 4 cylinders.
Either way, the mod for the 2 wires coming off the stator is a moot point really, they are connected once the lights are on with 360s, not just when the high beams are on like older bikes.
Discussion Starter #16
Took some time off over the holidays to spend time with the in-laws. Back at it over the weekend with a new toy, a multimeter. Went through all of the wires in the harness to better understand the electronics. Not very photogenic but quite satisfying.
Discussion Starter #17
Very successful trip to the salvage yard yesterday. Got a seat latch, which I gutted to just open with a screwdriver. Picked up a complete rear brake pedal to fit with the low pipes. Also found a housing for the ignition key. Wiring the bars with a new start button is still a work in progress...
Discussion Starter #18
Front brake is coming along. Rebuilt the master cylinder last night. Scrubbed out the inside with scotch brite, which helped with the corrosion but it’s still a bit stained in there. Also, managed to pop out the caliper piston with compressed air after loosening up the old seal with a heat gun. Thing popped out like a rocket! Hopefully will get it reassembled with a fresh seal and bled in the next few days.
In other news, my carburetor needs a deep, deep cleaning.
Make sure you give the grove for the seal in that caliper a good scrape. The brake fluid gets in behind the seal makes a nasty crusty deposit that makes the piston stick in the first place.
And dear god why did someone use silcon sealer on that poor carb? That's gonna take a while to clean up and out of the passages if it got loose. :cry:
Discussion Starter #20
Basic fuel tank rehab. Replaced the cap seal, which was unexpectedly annoying. Rebuilt the petcock. I was perplexed by this little o ring though. Seems like it should fit on the nut that joins the petcock to the tank but there wasn’t an old one there and this new one didn’t seem to easily fit on either side. Thoughts?
1 - 20 of 76 Posts
