1 - 20 of 33 Posts
Hey guys, I have my first engine completely apart right now. It’s from a 1973 CL350 K5. I’m wondering if there’s a list of parts I definitely want to replace before reassembly? Just wear parts stuff that you would be wise to replace now to avoid splitting cases again soon.
So far I’m doing:
Rings
Clutch plates
Stainless steel hardware
Starter motor and clutch rebuild
Had my cams and rockers resurfaced
Maybe clutch and valve springs - haven’t measured them yet.
Any help is much appreciated on my first engine build. Thanks!
Add Cam Chain tensioner Rollers and Cam Chain to the list.
And of course ALL Seals & Gaskets.
Reactions: dmfcb750
Absolutely agree with Yendor's addition to the list.
who did your cam and rockers? how did they turn out? can you post a picture?
Per your great advice on my project build thread, I sent them to Jon at Delta Cams. He called me last week and said they arrived, but I haven’t heard back since so I assume he is still working on them.
Anyone know where to get this without dropping the $180 that Common Motor wants for it? Honda CB350 Cam Chain Tenisoner Kit | Common Motor Collective
Their prices are often high, but in this case they seem to be out of stock on that set anyway. I might be able to save you a couple bucks if you buy the parts individually... I think I still have a new 350 center roller I ordered by mistake for my 450, you're welcome to it for the cost of shipping
Noooooooo. Is there anywhere I can buy them cheaper than Common Motor's kit? I can't seem to find them on the online parts stores that I know of. And they're always out of stock on the parts fiche sites like CSMNL and Bike Bandit.
I'm not in touch with more possibilities for the 350 engine, I haven't owned or worked on one in 40 years. :( I'd search eBay, 4into1.com, even cmsnl.com if necessary (though their shipping will be higher)
Discussion Starter · #13 ·
Sorry, I missed this post earlier. That would be amazing. I will definitely take you up on that, sir. Do you want to PM me paypal details or what's your preferred method?
I have found the intake valves are often worn with a groove in the sealing surface. Exhaust valves are generally OK if they aren't burnt. Since you are deep into this build I would suggest a new set of valves.
The valve springs .... usually the inner springs are out of spec the most. I think I have found 8 or 10 in spec ones out of 40 or 50. The large springs are usually better but I would say over 40% are out of spec. No one seems to be selling aftermarket springs that match the OE and I wouldn't suggest going to racing springs.
The piston rings are over half of what a piston and ring set go for and again very seldom do I find serviceable cylinders so I would suggest having your pistons and cylinders checked. New pistons, rings and a rebore is the way to go.
I usually figure that I will use parts from at least 3 or 4 engines to get one without having to do rebores and valve jobs.
Time and money.
take your cylinders, head and pistons to a machine shop and have them measured...replace what's out of spec. make sure you give them the specs from the OEM shop manual.
by the way, I usually don't replace the cam chain unless it's obviously bad...just the tensioner rollers. if your cam chain is worn then so are your cam sprockets...
Shameless plug for HT member TOOLS1 for machine shop work. He does honest work for a good price.
Reactions: TOOLS1
1 - 20 of 33 Posts
