The engine also had the valves done by my machine shop buddy - they did not leak, for sure.
KERRY said:You might want to try a compression test before you get into trying to solve a fuel supply problem. Leaking valves, worn rings, holed piston etc. will result in a non-firing cylinder no matter what else you do.
Hasn't happened to me but someone told me about this scenario once... thought I'd pass it alongChris Garrett said:The contact points cover was making contact with the points...
It's actually pretty common on a 450..........mitchellsk said:Hasn't happened to me but someone told me about this scenario once... thought I'd pass it alongChris Garrett said:The contact points cover was making contact with the points...![]()
i find this subject interesting...i have had the same intermittant problem. thought condensor was acting up for the one side. I think i will put a thicker gasket on my points cover plate. also......why would they touch?....quirk in the mfg process that was overlooked? Doesnt really matter how but i will def take precautions.tbpmusic said:It's actually pretty common on a 450..........mitchellsk said:Hasn't happened to me but someone told me about this scenario once... thought I'd pass it alongChris Garrett said:The contact points cover was making contact with the points...![]()
zx12ryder said:i find this subject interesting...i have had the same intermittant problem. thought condensor was acting up for the one side. I think i will put a thicker gasket on my points cover plate. also......why would they touch?....quirk in the mfg process that was overlooked? Doesnt really matter how but i will def take precautions.
thats exactly my problem......sometimes when stand the bike upright off the kickstand while its idling it will happen so i got some in depth wire inspecting to do.KERRY said:I've had the insulation on wires from the points wear through where the wires pass through the front of the side cover. It gave me an intermittent miss the cause of which I couldn't find (don't you hate the ones that always work correctly when you're looking for them?) until one cylinder cut out and stayed dead. Not that I actually thought it was the problem, but I moved the wires (externally) around and the cylinder started firing again. Although the problem was initially hard to find, the fix was easy.
