The bike I'm working on had a sissy bar that replaced the stock rear fender bolts that hold the grab bar to the fender, what size and length do I need for repalcements? I'm happy to get non-chromed ones from the hardware store.
Thanks
If you are just discussing the bolt that holds the rail, it's 8mm by about 10mm longer than the tube it installs in/through..and should be 8 grade (6 grade might shear),.... If you actually mean the fender bolts, they are special shouldered ones you won't find at a hardware.....
