I'm planning on not using my starter and just go with the kick start instead. the question I have is what size battery can i go with? Currently i have a 12A-A battery so its a 12 amp, 12 volt battery. Im just looking for the smallest battery that will do the job so it can fit behind the seat. I found these TekBatteries online which are the smallest i could find. However i don't know how many amps or volts that is required. I can wire the bike but i just don't know the physics behind how many volts and amps i need etc...Any help? Cheers.
PHIL from Canada
www.pvsdesigncaferacer.blogspot.com
You'll need a 12 Volt battery whose amperage rating roughly equals (but slightly exceeds) the number of amps the remaining components draw......
Ok thanks i think i get it now, I'll find out how much the head light, turn signals etc combine equals and just find a battery according to that answer. I'm making my own brake light and rear turn signals using LED so i should be able to figure that out once i add all of them. Thanks again.
Watts/Volts=A give youself a margin of error, brake light, horn, turn signals and headlight high beam all going at once = starting place for how many Amp draw you will have
AGM batteries are smaller than conventional wet cell batteries and they last longer plus they hold way more cranking amps too.
thanks guys
i totally forgot what i learn in physics class back in high school. it all came to mind after seeing that chart, thanks again for the advice
