1 - 10 of 10 Posts
I'm told there are different type points used on these bikes, and you must have the correct type for your particular machine? also there is a way to tell which is which, pitts? in base plate or points with one brand or another? I am confused.
Probably best to call your local Honda dealer and see if they can get you oem points. A bit more expensive
but should last twice as long.
It was a Honda dealer, DFW in Dallas, TX.- the head of the parts dept. asked if they were Toyo or Denso points, and said you could tell the difference because one or the other( he didnt remember which one) had pock marks or indentations on the points. my 175 has marks on the point base plate but not on the points themselves. my cl 360 has marks on the points and base plate. but I dont know what brand has the marks and which dosent, or if they interchange.
I think they're denso. Is it spelled out in the manual?
Honda used Denso and Hitachi points, depending on which points plate you used.
The online parts description page for your Honda will tell you what brand oem is standard for your bike;I think you can use any brand that says it fits.I prefer ND oem points for the CB350;the other brands you mentioned are good quality also and will fit if they are the correct part# for your bike.
IIRC Theres a difference in the set screw between the Denso and Hatachi, which is why the plates are different. Both plate should be stamped cb93. A cb200 set will also work ( with a 200 plate). A while ago there were a bunch of complaints about points not fitting, these were actuall cb100 points that sellers were claiming would fit.
Post a picture of the points plate and we can see if we can wotk out what you have
cb175 points
Thanks for the pictures Richard.
The plate on the left (silver) is Denso
The plate on the right (gold) is Hatachi
what i have is the Hatachi point plate, so I need Hatachi points? The young man at the Honda dealership told me he had Denso and Toyo points to fit. I assumed since its a Honda dealership they would be OEM points, but I didnt ask- so the Toyo points would be aftermarket? i dont know if it helps, but my engine # is cb175E 7018833. I just want to get the correct parts!
1 - 10 of 10 Posts
