1973 Honda CB175
Bought the bike, ran fine. needed some stuff - cables, tires and tubes, chain, paint, cleaning.
I put new NGK plugs in, changed the oil, drained the gas, put new gas in and did all the above.
went to start it, and no go.... would only start at full choke, full throttle, and then wasnt running right. would die out right away.
pulled the carbs, cleaned them. same result. bought a new set of OEMSTD carbs, installed. same result.
pulled the plugs, good spark on both.... one plug was black, the other still looked brand new.
i cleaned out the petcock, and drained the gas again, put new gas lines on it... but havent tried to fire it up again....
its kinda cold here right now in Colorado... so figured i could wait.
any help? whats with this problem? i think most carb issues are ruled out since i swapped them (stuck float, stuck needle, whatever).
thanks!
Will
thanks!
Will
