74 CL360, 81 CM200T, 85, 86 & 87 CMX250. Invisible to cages, treat accordingly. Avoids Road Rage!
1st, I'd again very much like to thank Dr Acula for this CM200T motorcycle.
I have recently installed rectangular mirrors from China, cost $15.
I found that the front sprocket 16T was easily replaced for an 18T with plenty of room to spare. Although it couldn't go even 1 tooth more. It works quite well, & doesn't touch the sides even at 65mph.
The engine revs much lower now. However, it still will not exceed 65mph, so, next I'm going to direct my attention towards carburation. It runs very well, it's just that I think that with 17HP, it should be at least equal to a 2nd generation Rebel which has 17HP. Any ideas as to top speed improvements?
(Other than the 'Correct' answer, "If you want more power, get a bigger bike!")
