Should idle rpm's increase when the engine is warm? I'm running Mikuni VM30's on a CB350. Cold, the bike idles at a steady 2000, but after riding around for a bit when shifted back into neutral it idles around 3500 rpm's. Still transitions smoothly into gear but I'm not sure if it should return to the initial idle speed or if I should be setting the idle speed based on the warm engine idle. I set the roundslide idle height using a 3/16" drill bit as this was the smallest size I could use. (the screw reached a point where it no longer effected slide height when turned)
