1 - 11 of 11 Posts
From my Bomber - DOES ANYONE AHVE ONE THEY CAN TURN LOOSE OF ? Is there a new one available anywhere or does anyone have one or an idea on what to do ?
Re: Chain Tension Idler
Rick..... I'd replace it if you can locate a new (or better used one).... Depends on the "brittleness" or resiliance of the rubber.....The center ridge looks like it's starting to "chunk" out already......
I could make these; need to know what material(s) to use.
Any ideas ?
Personally, I think Teflon or Nylon would work....The question would be how to affix them to a steel or bronze bushing...L/H threads maybe?....
I'd buy a couple - last one I got had to come from one of our Aussie members.....
While you're at it, make some replacements for the cam chain tensioner roller......
Anyone out there have one to let go of ????
Please......
Rick.... I have one used one, and while it looks better than yours, is not 100% either..... E-mail me as [email protected] ... I can take and send pics if necessary.....If you'll cover shipping, you can have it on an approval basis...I was stockpiling it as a spare.....
Hi Rick
Years ago (1975 or so) a friend of mine made up the roller that fitted into the cam chain tensioner, out of nylon, which worked very well. I believe that to fit the bush he heated the nylon, having previously slightly undercut the central hole ("interference fit I believe it was described as). He warmed the nylon up then pushed in the bush. It never moved.
There are a couple of used ones on ebay right now, including one that looks like it is really good shape.
There was a Thai company advertising brand new ones on ebay a few weeks ago, but I don't know what happened to their ads.
Also check on the web for an Italian racing parts company (I think called "Capellini" that makes a metal sprocket to replace the rubber wheel).
The whole design sucks... who thought it was a good idea to have a rubber wheel riding on a chain? It like driving on speed bumps every mile you're on the road!
I need to replace mine... it is TORE UP! But I think I'm just going to ride it until it breaks or I can get it into the rebuilder next Spring.
71hondacbtwin
1 - 11 of 11 Posts
