I have a CB stand, pivot, and spring, though it doesn’t have the frame-stop like the CL one does. If you’ve got a welder that’s an easy fix, otherwise they seem plentiful on eBay :)
I only know (and have the spare) because I indulged just last week! :D that frame stop is key if you don’t have OE mufflers on the CB. I gerry-rigged a new rubber pad by getting a vibration damper like this (https://m.grainger.com/mobile/product/2NPE3), using a box knife to cut off the female threaded portion, and then a wire wheel to shave the rubber down thin so the center stand retracts as much as possible. Maybe that’ll save you some trouble :)
Yes, without the stopper, your centerstand will smash into the chain. I also improvised a stop with mine when I didn't have OEM exhaust on the bike.
