Planning to make a 2 to 1 intake to use this motor on an atv. Not asking for free. I meant no rubber needed.
I would advise against it. the carbs will get you the max hp. unless you go turbo.
What I'm wanting to do is to make this low mileage motor, that came without carbs, frame or external electrics, live again. I will be using my version if flywheel triggered ignition. There is no motorcycle involved, as I have 5 others that run, to fill that role.
I'm not looking for max hp. When I bought this engine and exhaust, the odometer only showed 7 miles, bit it only had one carb boot and no carbs.
After doing a lot of reading, I've come to understand with this 180 deg. engine, I need to run dual carbs. What other engines use the same mounting bolt spacing for the carb boots, as the 450A. I'm thinking I can port to match whatever boots will bolt on and get carbs to fit those boots. Larger venturi carbs can be rejetted.
Sense I had no stock carbs, I welded up some steel boots and used two Keihin PD41's from a rack of 4, that came off a CB750f. Along with a homemade ignition, this 60 dollar, craigslist find is running. Still got some tuning to do but at least I know that it runs.
