I have VM on my 72 350. One side of the cable will need to be tightened with the adjuster at the top of the carb. They should respond to your throttle input at the same time and at the same speed. There are other great posts on syncing.
It's normal for that to happen, you lifted the slide and the cable stayed down because it's free to move up and down in the slot. as long as the free play is in sec the cable cannot come loose.
