Can someone advise as to whether it matters on the base gasket which side is down. These gaskets have glossy and dull finishes. I thought about this as I was setting the cylinders in place. The head gasket doesn't show any difference, so I just installed with proper orientation.The other gaskets are similar to the base, but have not been installed. No bolts in place.
Doesn't matter, either side up/out. Careful with the cam bearing holder gaskets, they only go one way , to line up the oil passages.
Reactions: f100owner
I am careful of lining up passages. Just could not figure out how glossy vs dull side would impact gasket performance in this situation.
