1 - 2 of 2 Posts
ive got the factory rebuild kit out and im replacing the o rings. there are a couple packets inside. one says QTY A one says QTY B . The package labled qty a is the air cut off o ring and im assuming qty b is the fuel tube o rings. that means the other two are for the needle cap and the float bowl screw. Is that correct? Am i going to be left with any extra parts?
For the pair of carbs there should be:
1 o-ring each end of the fuel tube
1 each end of the accelerator pump tube (Pretty sure VB22s have an accelerator pump),
1 for each mixture screw,
1 for each air cut valve,
1 on each needle,
1 for each float bowl drain screw,
1 for only the float bowl on the accelerator pump side (+ the accelerator pump diaphragm thing)
1 - 2 of 2 Posts
