1 - 1 of 1 Posts
The outer collar around the top of the valve retains the split keepers against the valve stem. It is just a little stuck because the keepers are designed to wedge against the valve stem and into the collar. Just give that outer collar a tap downward and it will come loose from the keepers.
Sorry this was meant to be a reply to gaillarrys post
Removing Valves
1 - 1 of 1 Posts
