Hi,
I have reached the point on my CB200 cylinder head refurb of ordering new valve guides. I have looked on the CMS web site and they give the same part number for both Inlet & Exhaust, Part No 12021-354-405 which has superseded the original part numbers, which differed for inlet & exhaust. Does anyone know if it's ok to use the same guides for both inlet & exhaust or is it an error by CMS.
Many Regards,
Glyn.
Hi Nige,
Yes I have already seen that link but it doesn't help much. It is just that my parts catalogue gives two different Part No's for inlet and exhaust, 12021-354-300 and 12023-354-300. Perhaps they just decided to use the same guide for both, but not sure.
Glyn.
I don't know about these engines, but as far as I know, the guides are normally all the same, and I see no reason why they would use different ones. Perhaps you could only mount the valve stem oil seal on one, and the other would not be sealed?
According to the FSM, it looks like Honda wanted the exhaust valves to fit a little looser than the intake valves so the guides are different. The intake guides may still work on the exhaust as long as there's enough clearance.
.......Paul
Thanks for all the input on the guides. It looks like I'll have to try running with all the guides the same as I can't find a supplier that sells the two different types.
Regards,
Glyn.
Regards,
Glyn.
A quality machine shop will hone the bores to fit precisely for both intake and exhaust valves so you have a relatively tight,low-friction fit.
Though they're not tough to install, new valve guides are NOT ready to go out of the box.
Once installed, they need to be sized with a precision reamer - a machinist would take care of it for you.
