1 - 10 of 10 Posts
Hey all,
Does anyone have the specs for the valve clearance (both intake and exhaust) between the valve and the cylinders for the 360T?
I have a 1977 CJ360 that I'm considering shaving the head and/or decking the cylinders and I'm trying to find out how much room I have to play with...
Thanks,
Sonny
PM me for a site you can download the manual from.
You DON'T measure between the valve and cylinder to check valve clearance..... It's between the valve stem tip and the rocker..........
To check for a "decking" process, you have to assemble and "clay" the parts......
Check my project log for a how to....I did it twice :roll:
You machine the valve "pockets' in the piston crowns deeper.....Why do you have a specific amount you want milled off the "deck"? ...Are you going for an extreme compression ratio, is the surface damaged, or what?..... Stock ratio is 9.3/1, anything over 10/1 will cause other mods to be required....
No specific reason. It's just that 1.0 mm shaved works out to be a final static compression ratio of right around 11.1:1 and that seems like a good number for building power. Probably going to end up with a regind on the cam as well. Anything else to keep in mind?
At 11.1/1 you'll need to run Cam2 (full race fuel) at about a zillion $ a gallon.....
(A 9.0/1 engine requires 93 or 94 octane fuel.........)
Plan on adding an oil cooler and larger capacity pump as well
You might be better off keeping the stock ratio and turbo-charging the engine.....
I don't even remember the last time I saw 94 Octane. Not even sure 93 is widely available here in Vancouver, WA.
Didn't realize you were so close to me, Sonreir. May have to get together for a ride some time. Though apparently you're bike will leave mine in the dust in the near future, so maybe that should happen sooner than later. :x
1 - 10 of 10 Posts
