1 - 14 of 14 Posts
There is only one brand of carb sync tool you should spend money on, Morgan CarbTune.
http://www.carbtune.com/
Guages cannot be accurate, it is not possible.
Close is not good enough for me, I have a CBX with six carburetors and 2 Morgan CarbTune 4 cylinder carb sync tools is the only way to get perfection.
Morgan does sell a twin cylinder CarbTune.
I've used manometers (mercury and water types), Gauges, and the Morgans...You won't be sorry, and you can make back the cost by syncing your buddies bikes....
I just took delivery of a set of Morgan Carb Tune gauges and they look great. I'll be using them on the Gold Wing in the next few days. I'm getting ready to drill and tap the intake runners on the 450 as well. I'll use 5mm screws to plug them when not in use.
Be sure to use a soft aluminum or copper washer with the screws.........
Yup, will do. I also got the carb rebuild kits in today as well. Hopefully, I'll get those finished up this weekend. After that, the motor get mated back up to the frame. They've missed each other. :)
I'd love to see the way you go about drilling and tapping those intake runners for the vacuum nipples.. You always do good write-ups so I hope you add this one to your list.. ;) :D
Bird76Mojo said:
I'd love to see the way you go about drilling and tapping those intake runners for the vacuum nipples.. ..... so I hope you add this one to your list.. ;) :D
Sure thing, will do.
Drilling...tapping...nipples....my ears just pricked up! :D
Discussion Starter · #12 ·
Discussion Starter · #13 ·
Go back to sleep lee :) it's work we are talking about :roll: any new developments on the 360 :?:
Rod from OZ :cool:
1 - 14 of 14 Posts
