So about a week prior I noticed that t bogged down real bad anything last 1/3 throttle, maybe even a 1/4...after not using it a handful of days. I chalked it up to most likely the carbs needing cleaned... then on the way home from the gym one day and entering my neighborhood I heard a metal noise from the top end and found this...
I?m not sure if the nut backed off the adjuster and it?s what cause the nipple to fall in? Or vice versa.. any thoughts ? I can only assume I have to remove the top bracket at a min.
