So my bike wasnt starting, which was very much a bummer. hit the ignition switch, and no crank, no click, nothing. kaputski. After pulling my hair out for a good two months, testing, cleaning, dielectric-greasing, i ordered some of the cheaper parts because, hey, why not. I ended up switching out the solenoid, because the lack of audible click made me suspicious.
And it cranks! huzzah! so now i have a new problem: it cranks, and seems like it wants to start....but wont. I checked the spark plugs, and they spark the recommended distance. the gap is also at factory specs. at first i forgot to use the choke, and so for a day at work thought that might do it. so i pulled the choke out, put the freshly charged battery back in, gas on, switch on......ignition, and.....cranks, and seems like it wants to start, but wont. when i held down the ignition button and pulled the throttle it revved a bit, but it didnt sound right and wouldnt really come to life on its own. cut out right when i released the ignition button.
it was stored in a garage over the winter, but it isnt a very good garage. its fairly damp and when it hit -10 a few weeks ago, it was probably pretty close to that in the garage. could it just be wet inside the motor, would warming it up with a blow dryer help? i want to try and avoid taking the engine apart, since 1) that scares the hell outta me, and 2) i dont really have money for a mechanic if i really screw something up...but opening it up and at least cleaning the carbs seems to be my only option.
Any suggestions? i have a few bike-savvy friends i intend to ask, but any help i can get on my own from you folks is my first resort. Again, thank you all for your help.
Key on
Confirm you have spark
Turn on gas
Count to 10
Pull choke lever
Snap throttle 7 times quickly
Hit the starter... For like 3 seconds max, no throttle.
Does it fire?
Was the bike running OK then suddenly developed this problem. Was it stored for a time then developed this problem?
Compression tests are best done on a warm engine but even the results of a cold test could be useful since we know you have spark.
You could also spray a bit of starter fluid in the air cleaner then try to start it. If that makes it run for a couple of seconds you'll know it's not getting fuel. Nice to be sure before you pull the carbs.
