So I bought 2 new turn signal lights to replace the stock ones. They are not LED lights. These come with 3 wires...black, brown and red. So to test, I simply took out one of the turn signal connection and try this on. They don't blink no matter which wire color I plug into it. If I ground, they will stay lit(but not flash) if I don't ground, nothing happens. Also, this light have 2 brightness levels. The red wire is brighter than the brown wire. Anyone have any ideas? Thanks!!!!
I know it's not a electrical problem because as soon as I connect the stock signal light back, it works.
