Hi Everyone, This might be stupid, but I've been trying to figure out how to get the stator off of my bike for a bit now. I've got the main bolt off, but it seems there's something still holding it in and I can't quite figure out what it is. Help is greatly appreciated, thank you!
What do you mean by stator?
In this diagram do you mean part 4 or 5
If part 4 you need a rotor puller (an even bigger bolt) to thread into where that big bolt came out of. There are lots of youtube videos on rotor pulling that will explain better than me typing
You need to buy a flywheel puller like this one. Mine is a 20mm, but yours might a different size since you have a 450. Screw it tight, then you hit pretty hard with a hammer while you screw it with a wrench.
While you are at it, you'll need a flywheel holder ( adjustable Iis better) to put it back and tight you bolt to spec. Lots easier with the proper tool and you'll need them again eventually.
