Hello all, i’m working on my first motorcycle, a 1981 CM200T (12volt) to be exact. It has been a task to start the bike since I bought it a few months ago. I’m finally at the point where I have what I need to start the bike, and nothing happens. The kickstart turns the engine, but won’t start combustion. The electric start (hooked up to an alternate 12V source) turns the pistons, but again, doesn’t start combustion.
I have tested the spark plugs and they produce spark.
I have observed the carb bowl fill, and the amount of fuel in the fuel line go down while trying to start the bike (petcock OFF).
I have tested the carb mounted choke in both positions while trying to start the bike
I have tweaked the throttle position while trying to start the bike
I have tried starting in neutral, clutch in and out.
I’m not quite sure what the issue is, as the bike has only 3000 original miles and the engine seems to be perfect on the inside. I’m wondering if anyone has any suggestions. Also, if you’re interested, here’s the story so far:
When I got the bike, the carburetor was nowhere to be found, so I purchased a copycat carb from ebay that matched the bike alongside the manifold in order to bolt onto the engine
I’ve swapped the engine oil and spark plugs with their respective new replacements. Plugs are also gapped correctly.
I’ve lubed the cylinders with marvel oil and have rotated the pistons like butter with the kickstart lever AND starter
i’ve cleaned the fuel tank of rust and installed new lines and an inline fuel filter
i’ve ordered a spare 12v ignition coil that i’ve discovered that I might not need, as it gives the same multimeter readings that the original (which I thought was faulty) read.
RUST, SO MUCH SURFACE RUST. Tons of rustoleum jelly and wire brush time
