Ahhh, so the disc brake was the transition year? What about the K3 CL model? Did they have black triples?66Sprint said:Mike, They went black along with the advent of the disc brakes......So Black is correct for the K3... Steve
Part # for CLK2 = 53230-292-020 (same as CBK1)MNellis said:Ahhh, so the disc brake was the transition year? What about the K3 CL model? Did they have black triples?66Sprint said:Mike, They went black along with the advent of the disc brakes......So Black is correct for the K3... Steve
Thanks Bill.tbpmusic said:Part # for CLK2 = 53230-292-020 (same as CBK1)MNellis said:Ahhh, so the disc brake was the transition year? What about the K3 CL model? Did they have black triples?66Sprint said:Mike, They went black along with the advent of the disc brakes......So Black is correct for the K3... Steve
Part # for CLK3-K4= 53230-320-000
Part # for CLK5-K6 = 53230-319-305 (replaces 53230-319-000 ???)
CLK6 had tach/speedo slanted toward rider at a greater angle than K5, due to changed bracket.
K1-K2 have same forks (probably)
K3-K4 have same forks
K5-K6 have same forks
