Re: Tripple clamp & carb mounts for my CB360
This page may end up being of some help for you??
http://www.sudco.com/flange.html
That is kind of what i have been wondering is if i could just swap the clamp or if i needed the whole tree. I have been thinking of just converting the bike to a part I should never have to worry about ever cracking again and install tapered roller bearings at the same time.tbpmusic said:On my mutant 450, a 400T front end bolted right up to a 360 stem/triple clamp. I believe the 400T and 450T (Hawk, not the old DOHC 450) are the same thing in this respect.
So I'd say it would work the other way around, too - but you'd have to use the 400T stem and triple clamp as a unit.
The 400T stem is a bit shorter than the 360, because of the flat steel triple clamp. So it wouldn't work with the 360 stem plus a 400T triple clamp.
I think the offset is a little different too, but that shouldn't affect what you're trying to do.
And you'd be on your own as far as mounting the speedo/tach, as the two bikes are totally different in that context.
I just happen to still have the 400T stem and clamp in my shop......
Yeah, I forgot to mention that - the 400T top clamp is actually held in place by the fork cap bolts - there aren't any pinch clamp thingies like on the bottom clamp.66Sprint said:I'm not certain about the "steel top" forward offset being different or the same, (never had one) but the width definitely is....Using Bill's matched top and bottom trees would be the way to do it properly... You will however also need the "special" top cap/bolts that fit with the steel tree as well... They should screw right into your tubes......
So, what's that stem & clamp worth to you?tbpmusic said:Yeah, I forgot to mention that - the 400T top clamp is actually held in place by the fork cap bolts - there aren't any pinch clamp thingies like on the bottom clamp.66Sprint said:I'm not certain about the "steel top" forward offset being different or the same, (never had one) but the width definitely is....Using Bill's matched top and bottom trees would be the way to do it properly... You will however also need the "special" top cap/bolts that fit with the steel tree as well... They should screw right into your tubes......
The 400T fork "caps" are no longer available - I may have kept the old ones - I'm not sure, they were rusty and may have got tossed.
I replaced them with early CX500 caps, which worked in the 360 top clamp just fine.
Sure, I'd sell the stem and clamp......
