I just took my case apart to inspect the tranny and replace parts as necessary. I noticed this wear mark in the case (from a gear) and also noted some abnormal wear on the adjacent shift fork. Is the shift fork bent a little? Is the wear caused by the shift fork? This is my first time in a 450 tranny but I’m familiar with the shift detent star and roller issues and that they can cause other shift fork problems. The bike did have an issue popping back into neutral from first and second.
Edit: here’s another photo of the shift fork in question:Is this wear too much and is the gear wear on the case a cause for concern?
