I don't know what I'm doing so bear with me. When I got my motor back from the shop it was not "torqued". He told me to do what I had to do and bring it back. Well when I was ready to bring it back, I made a call and the number was disconected, I drove by and there was a for lease sing in the door. Poor guy was another victim of the times. So I'm left with some questions.
I borrowed two torque wrenches from a guy at work, one has a spinning end that allows you to turn to how many lbs you need and clicks when you reach the desired ft/lbs. The other one has a handle at the end with a pointer that tells you in inch lbs where your at. My question is which wrench should I use, and how to I get a precise measurement (not a whole number), and does the inch/lbs wrench equate to the ft/lb wrench (if not is there a formula that does)?
Here is what the Clymer's service/repair handbook tells me I need to torque down:
Cylinder head 2- 6mm bolts (near spark plugs) at 6.15-7.23 ft-lbs
Cylinder head cover 8- 13 mm cap nuts at 13-14.5 ft-lbs
Cam case 4 - philips head screws at 4.34-5.42 ft lbs
Thanks, I hope I didn't confuse anyone
