hi all, new to the forum. I just bought a rusted non-running 1971 cb450.(k4?)my first project bike. it will be exciting. i will post pics at some point. the top triple tree bridge piece holding the forks was cracked in two places, so i replaced with one off of a 1975 500Twin. I have seen a post or two that makes me wonder if the spacing and offset are exactly the same or not or if I am causing a problem using the original lower triple with the 500T top triple. only major difference i saw is that the 500 has an extra ring for the iginition and that the gauge mount holes are in a different spot. no biggy.
anyone?
also, I have access to this doner bike for about a week, i just have to swap the parts. I will be comparing things for cosmetic stuff, and trying to get mine running so I know if there is any mechanical things I need to change, but is there anything that I should just swap because the 500twin has better?
as in the front forks? they dont have boots, which is kinda nice, and mine are super rusty pitted between the 2 triple trees.
or the whole front end? does the 500t have a better disc brake piston system?
mine also have bicycle tire valves in the fork caps for adjusting the fork air pressure i guess, dont know if i want that or not.
which forks are easier/cheaper to rebuild?
thanks for any info!
anyone?
